Mini PC vs Android box
So im in the market for a Nvidea shield. But then i got thinking…
Would a compact mini pc not be a better option? The advantages i see are
-ram and memory upgradeable
-os as well
-can simply create a windows share to copy my media files from my main pc to the media center mini pc
The only downside i can think of is that its slighly more difficult to get the airmouse remote control to work, but thata not a biggie
And it will probably need a a decent gpu.
Thoughts?
Hi @TheClown,
Mini PC running Remix OS (Powerered by Android Marshmallow but for PC) would be my choice if you are going to use it as a media player.
http://www.jide.com/remixos-for-pc - Remix OS Link
Mini Pc is better… all the advantages and you can just run bluestacks or a similar android emulator for the same effect and apps as the android box…
Or as @Firestarter saids :wink:
I’m running plex on a Ubuntu server in a VM.
Don’t think you need a decent GPU as it will only play video.
Hands down the mini pc i always just use the Android box for the less technically minded
Mini pc my vote…im running a NUC as media center …no issues with wireless mouse and keyboard combo
even the PEN pc with windows on is a gem
Depends on the hardware. My HP Micro-Server for example was not designed to play videos (even with the correct display drivers) it struggles with video.
Remix is awesome but i would probably run win10 for simplicity.
Its just to run “the K word” anyway.
If I may ask, why in a VM when there is a native Linux Plex server?
A post was merged into an existing topic: HP i5 EliteDesk 800 G1 (USDT) + 1x 20" Samsung LED Monitor (R2500)
If for some reason I reload windows on my pc I can just start up the VM(I use VirtualBox) and all my services running on it is back.
i use a microserver with LP gpu modded bios 8gb ram windows and plex loaded and a rii i28c for wireless keyboard and mouse small enough also more then enough space for storage way better than my previous media player (Mede8er) so yes i would also say mini pc is best option more options and not limited like with media players
Wait What? Link Please?
https://www.pinnacletech.co.za/stick-pc
haha i see they have the Remix Mini Android PC on sale
https://www.onedayonly.co.za/remix-mini-the-world-s-first-true-android-pc-5.html
gaan oor meer as net plex
I gave up on pc as I could not find a good streamlined way to incorporate youtube and netflix etc into a simple main menu. although i do use plex 70% of the time.
I also use streaming music.
So if you want to be able to use streaming music (internet like google music , deeser etc) i would suggest android based.
I got myself a xiaomi mi box. Which runs android tv that has google cast built in.
plex works flawless on it from my microserver.
google music.
casting from any device be it plex ,
not cheap:
but cheaper than nvidia
@tangmonster911, I know these well, I have the Minix Neo X8h Plus which is considerably better apart from the OS.
The Mini PC was just a 2nd option, and the problem with android boxes are that the OS gets outdated every 2 years or so. But now I have both :slight_smile:
If anyone else is reading this and wants to get an Android box, just look at the ram/rom (3/32 is best), and the OS (Right now I would look for an android 7 box, but not less than 6)
These boxes are really great , I have been totally happy with all my boxes over the last 5 years.
Will NEVER need DSTV, SABC, Netflix or anything similar.
