--Newbie_Wynberg--
WiND Node (link or at least name and number):
List your existing wireless equipment (but don’t buy anything):
Confirm with yes or no that you’ve read the getting started guide:
Description / Details of your issue below
Hi ive been intrigued by the CTWUG. so i got me a SXTG-5HPacD. its mounted and currently on.
made my wind account. and created my node(abubakr) but i have no idea what to do next.
im a techie so im here to learn :slight_smile:
I probably shouldn’t have got the equipment 1st. lol anyway… when i go into the router its always “searching for network”
is that normal?
How do i get on the WUG grid like all the cool kids?
Im from Wynberg. my node is (abubakr)
my router is above ceiling level but i can extend it to above roof level.
oh and i tried reading the full getting started wiki but i get a 403 on step 3 ???
Yeah, that’s 100% true.
I believe an IP range will need to be provisioned for you from one of the Network Admins.
anyway from Wind I see you are trying to/interested in connecting to the Mercury HS. Can you do a quick scan with your SXT pointing in all directions (360 degrees) to see what the results are and post them here?
You can do it as follows:
The results should be something like this:
Depending on the results above you might have to tinker with the height of the SXT - also note that, it’s best to have Line of Sight with the HS (In other words you should be able to see the building with the sector on it)
https://wiki.ctwug.za.net/wiki/Scanning_using_Winbox
thanks Diesal & the Clown
so i did a scan and thats what i got.
then i did a 360 and the best signal i got was from “ottery-silvermist”
and i could connect to it
im not sure what node it is on wind though.
Il probably extend my router higher eventually, but what do i do next?
No the addresses you need to look for MUST start with http://ctwug… As prt the instructions. That is not a ctwug node.
Use winbox
Also set your scanlist to 5000-6000 instead of default
great thanks guys.
so i finally got the router higher.
got a signal to http://ctwug.za.net/Mercury3 with a strength of -63, which should be fine right?
whats the next step?
i added a link as a client on wind already to http://ctwug.za.net/Mercury3
because when i connect it just keeps on searching for signal.
do i change my ip of router?
