Walka 7 mobile TV
Since Multi Choice axed this device, is there any other uses for this.
Is it worth opening up and see what’s inside to use, maybe.
If you are into DIY electronics and projects the only thing of value in that unit is the battery and the speakers.
Unit cannot be re-used for anything else.
Screen can maybe be used with a raspberry PI to make a Hand held gaming console or the Likes but you will have to be very technically and Mechanically inclined to fit and finish it nicely
I had a unit like that and removed the screen, battery and speakers.
I doubt the screen can be reused - you will need the driver for that screen which I’m not sure you can track down. That ribbon cable is so delicate and has a million connections. Easier to use a screen that comes ready for HDMI for projects like that.
