What microserver are you using?
Hi All,
Looking into investing in a microserver to keep my media on (for viewing in the household) and to link up to the WUG servers.
Any recommendations and ‘stay-away-from-…’ advice would be appreciated.
Currently have 2x HP Microservers, I absolutely love them! 1 i use for media storage and so on, the other for VMs and messing around. 1 of them is the new Gen8’s, which hosts is Intel based, uses alot less power than the older AMD unit. Totally recommend them.
Nice but flipping expensive
Yeah @herb1
That warlock072 guy is such a geld gat I tell you
:thumbsup: for the microservers.
lol, I built mine overtime, like a nice tower or mast, doesnt happen overnight. Esquire has these specials from time to time and the gen8 goes for R2000-R2200 exvat. Then i just bought an upgrade very 2-3 months after that.
Ok, gonna resurrect this again…lol
Which server would you recommend (don’t have to be micro-), cost-effective, efficient, least troublesome and long-lasting?
Reason is I’m connected to WUG via laptop and would like a server to do ‘the other functions’?
Any recommendations?
INTEL NUC with class 10 flash drive for OS and 2-3TB single drive for storage
@Keeva: how much is such a setup? The price of those drives are scary
You mean @Jeeva right?
R2200 ex from Rectron
  • Intel Next Unit of Computing Kit- Intel 5th Generation Celeron 2.16GHz Dual Core Processor, 1x DDR3 Memory Slots (Max 8GB supported) Low Voltage
  • Intel HD Graphics 5000, Integrated Gigabit Ethernet, Internal support for 2.5¨ HDD or SSD (up to 9.5mm thickness), Audio jack on the front panel
  • 2x USB 2.0, 2x USB 3.0, 1 x Half-Height mini-PCI-e slot taken up by pre-installed Wireless Card, 1 x VGA, 1x HDMI, SDXC card slot
Thanks for the description @Jeeva
Using N54L
4 HDs in plus 5th OS hd in the top.
8gb ram
Also using N54L 5x 8TB seagate drives, 16 gigs ram. Modified bios. Using xpenology from usb stick. Really great nas with lots of other addons and utilities. got a few of these N54L’s some with freenas. Really worth it.
Nice device. i lost hope in it after cpu blew right after 1st year of having device.
You guys are all using things that I can’t either: afford or no stock of :frowning2:
Would I be able to turn a simple tower into a multmedia server/storage device?
Yip. Easily. Dont even need the fastest pc in the world to turn it into a multimedia server.
@gekido: ons moet praat
The microservers are the ultimate…tiny but powerful but expensive and unavailable.
They are good as NAS, but you can do so much more. You can run them as storage and host a wug site or two etc.
You would definitely. It just depends on where/how you want to do it. Before I had the server I had a n old desktop doing the duty. Was my old desktop that I slapped a few HDs. You can keep windows or install linux or go to NAS type os. I don’t like the NAS type OS because it limits things. But it might make managing shares etc. easier than doing it from a regular linux distro.
If you have a space to hide the (noisy?) desktop it can be quite convenient. What you gain with microserver is lekker drive bays. Small size. Low power consumption (wich saves money).
