Alternative Connection(s) From/To Oude Westhof
WiND Node: Invoker #15199
Currently I have no equipment but is ready to buy , I have read the starting guide , talked to my area admin etc.
Not to insult or step on any ones toes , @Jypels is busy with a new business or something similar that i can understand takes a lot of energy and time. Me and @Bronzie has been trying to connect for a while but since we are a bit obstructed by trees , that makes it a bit harder. As my last discussion with Jypels there needs to be additional sectors on the Giftand nodes. I am not entirely sure what that equipment will requires etc.
Now also what i want to try and figure out if another long range link is perhaps possible to someone on the Kenridge side? I am sure me and Bronzie will be able to save up for something if that means we will be able to connect to ctwug.
(PS. There is a few nodes in my area that is not connected in anyway for a long time now yet wind shows it as active: Davisto , Poseidon , Dion. I have contacted them as well)
Regards
Parowdude(Arné)
Hi @parowdude
Could you perhaps book a test and perform a scan to see what nodes you detect.
This would give a better idea what options are available?
Kind regards
D
“Test” scan from phone
Thread can be closed.
