I need a watt meter to see how much power my devices are pulling from my inverter during load shedding to make sure its not overloaded or under utilised. If anyone has one that I can borrow perhaps, i would be grateful. Because spending R600+ for a once off measurement doesn’t make sense. Thanks
Amps x 220 (ac voltage)=watts
Yes i am aware, but have to go add up everything manually and do maths where i can just plug in a device. But I have a feeling I’ll end up adding it all up manually anyway.
Hi you only get an amp meter or multimeter what can read curent google wil help you
Not true u get a meter that can measure amps, volts, hertz and watts the one u can plug in like on aliexpress or wish and geewiz only shows watts and you can set the cost so it can show the amount it costs for a period of time
I have one of these on my power supply to my wug equipment and it is accurate paid R150 for it on aliexpress there different amps/models of these available
This one is the popular one everyone is using it gives you a basic idea of watts used and costs
