Brandy&Coke
Hi guys
Is any one having problems connecting to brandy&coke. I have lost connection since Friday. I have also been trying to get hold of Morkhans but no luck
I checked brandy & coke side and his other clients are connected, so it seem the problem is at your rb. See if you can login, if you can scan and connect please.
Hi Ogon
Thanks for the tip I re scanned, I got re-connected it looks like the frequencies was changed on brandy&coke side, but all good now
Hi guys
For those of you who has not joined the Google group for Edgemead, this is a notice that all brandyandcoke clients will be moved over to twosix tomorrow night in gametime.
Hi Organ
Thanks for the update. I belong to the CTWUG Bothasig Google groups still new at it how can i join the Edgemead one
The admin of your wind node is thaviper, so he has been invited you can pm me your email address or give it to me on forum and I can invite you.
not to fussy about my email address being shown it is mcbainshane@gmail.com
Thx again Ogon much appreciated
Invite send
Hi all
Big thanks to Morkhans for helping to move the clients over to twosix
New ranges for all clients are as follow
RedDragonZa
172.26.53.0/29
Ddbeyer
172.26.53.8/29
Lesage
172.26.53.16/29
Deathinc
172.26.53.24/29
Please feel free to contact me if you need help and don’t forget to update your wind accordingly
Hi Ogon/Morkhans
Thanks guys wind has been updated
Hi Ogon,
I have not had wug service for 2 weeks now please advise if i need to make changes on my RB
as per your message above ?
Regards
Dean
ddebeyer
Hi @ddebeyer
Can you rather post a new thread inside the support category. This thread is very old already.
Can you post results of the below as well:
In command prompt
ipconfig /all
ping 172.18.1.1
tracert 172.18.1.1
Also if you can get into winbox. Post a pic of the wireless status
The issue is at Majortom, oomshaun needs to do a site visit to fix some cabling issues.
Hi there
I am connected to brandyencoke fine but cannot ping dns 172.18.1.1 or tracert either
and my ipconfig is
ip 172.26.53.9 Which is my PC
subnet mask 255.255.255.248
Default gateway : 172.26.53.14 which is my Router
and as per Ogon see below
Regards
Dean
Hi Ogon,
So any idea when this will be done?
Regards
Dean
Hi Ogon,
Thanks for the reply and do you know when this might be resolved then?
Regards
Dean
