Europa Site
EU Maintenance tomorrow starting at 09h00. Expect downtime!
Hey Peeps,
Stays installed on both masts, as well as alignment to the Kingpin, TFyre and Bellville sector.
Europa is at full speed (X5 the speed at which it used to run). :smiley:
Thanks to Wacko141, Navigator and Redeamer2210 for the assistance!
Hopefully we do not need to go back any time soon. :stuck_out_tongue:
2mm staywires and my boltcutters what a fail :stuck_out_tongue:
Doing a europa visit this Saturday 22nd of June @ 10H00 in the morning. Doing some planned maintenance on some lan cables (replacing them), hitting some 5 port toughswitches (Becuase they are so reliable) and fixing the Europa-TFyre backbone.
Post here if you want to join :slight_smile:
Diabolix will you also check whats wrong with the EU-REDEAMER2210HS link ill activate the EU dish on my side on saterday morning
I tested the Europa dish pointing towards you, passed with flying colors. So it’s most likely at you, please disable CH1 and do a scan. Make sure you pick up at least >10 SSID’s and do the same with CH0.
Let me know!
Diabolix i think you should rather check it out just incase i delete all settings :stuck_out_tongue: i’m still in training
It’s really not that difficult
On topic: I shall be there
Hi,
Wacko141 will be replacing a dish on Europa this Saturday from 08h00 in the morning, there shouldn’t be any downtime, but if there is you know why :slight_smile:
Diabolix
Update:
Europa-Wacko141 is back online! Thus providing another redundant backbone to Stolla.
Update:
The Europa-Bellville-Sector (http://ctwug.za.net/Europa4) is now full!
dit is nou kaarkie2
 so ver ek verstaan het Stolla sy kit soentoe geskyf
Hi Peeps,
Europa pole 2 has been damaged. I could only see from the road, but the pole is super skew. Will set a date where I will be replacing the current bracket and adding another one as well as securing the stays.
Links affected: Kingpin,xraycat, bellville-sector
Diabolix - I work in that building let me know if I can assist with speaking with our facilities person in gaining access to the roof
 All tough I am sure that there is a contact in place already.
I can confirm that the pole does indeed sit at a ± 70deg angle from what I can see from the ground. Im in the building 9-6 please let me know who will be coming through Diabolix left a msg on IRC.
Thanks again for your help! Wacko141 will be coming through, he will be calling you to confirm a time.
I’m on my way right now, I sent you a msg on whatsapp
The current state of Europa: http://imgur.com/a/KSeHF
Ouch from what i can see it was plainly just not maintained often with all that rust on everything but then again it seems like its quite difficult to get any access to that place during non working hours but hope you guys do get that repaired and i am really happy nothing got damaged it could have been much worse :slight_smile:
