Having trouble connecting
#Problem Description: I cannot seem to connect to the wug anymore. Everything was working fine until a month ago. I didn’t change anything on my side. It was suggested that i post here. any help would be appreciated. thank you very much!
#Your details:
WiND Node: bumblebee #6749
PC IP: 172.18.242.43
RB IP: 172.18.242.46
RB has ctwug/ctwug login?: admin/********
#WUG-Check Script output
systeminfo
Host Name:                 LAPTOP
OS Name:                   Microsoft Windows 7 Home Premium
OS Version:                6.1.7600 N/A Build 7600
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Standalone Workstation
OS Build Type:             Multiprocessor Free
Registered Owner:          Jurgens
Registered Organization:
Product ID:                00359-OEM-8992687-00006
Original Install Date:     2011/03/17, 06:26:54 AM
System Boot Time:          2018/11/08, 03:19:46 PM
System Manufacturer:       Acer
System Model:              Aspire 5741G
System Type:               x64-based PC
Processor(s):              1 Processor(s) Installed.
                           [01]: Intel64 Family 6 Model 37 Stepping 2 GenuineIntel ~2266 Mhz
BIOS Version:              Acer             V1.08, 2010/05/19
Windows Directory:         C:\Windows
System Directory:          C:\Windows\system32
Boot Device:               \Device\HarddiskVolume2
System Locale:             en-za;English (South Africa)
Input Locale:              en-us;English (United States)
Time Zone:                 (UTC+02:00) Harare, Pretoria
Total Physical Memory:     3ÿ959 MB
Available Physical Memory: 2ÿ216 MB
Virtual Memory: Max Size:  9ÿ894 MB
Virtual Memory: Available: 7ÿ443 MB
Virtual Memory: In Use:    2ÿ451 MB
Page File Location(s):     C:\pagefile.sys
Domain:                    WORKGROUP
Logon Server:              \\LAPTOP
Hotfix(s):                 88 Hotfix(s) Installed.
                          [removed for space issues]
Network Card(s):           4 NIC(s) Installed.
                           [01]: Broadcom NetLink (TM) Gigabit Ethernet
                                 Connection Name: Local Area Connection
                                 Status:          Media disconnected
                           [02]: Broadcom 802.11n Network Adapter
                                 Connection Name: Wireless Network Connection
                                 DHCP Enabled:    No
                                 IP address(es)
                                 [01]: 172.18.242.43
                                 [02]: fe80::49ae:6f32:f100:6b0
                           [03]: Microsoft Virtual WiFi Miniport Adapter
                                 Connection Name: Wireless Network Connection 2
                           [04]: TeamViewer VPN Adapter
                                 Connection Name: Local Area Connection 3
ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection 3:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
Wireless LAN adapter Wireless Network Connection 2:
Wireless LAN adapter Wireless Network Connection:
   Link-local IPv6 Address . . . . . : fe80::49ae:6f32:f100:6b0%14
   IPv4 Address. . . . . . . . . . . : 172.18.242.43
   Subnet Mask . . . . . . . . . . . : 255.255.255.248
   Default Gateway . . . . . . . . . : 172.18.242.46
Ethernet adapter Local Area Connection:
Tunnel adapter Local Area Connection* 13:
Tunnel adapter Reusable Microsoft 6To4 Adapter:
Tunnel adapter Local Area Connection* 14:
Tunnel adapter Local Area Connection* 11:
Tunnel adapter 6TO4 Adapter:
Tunnel adapter Local Area Connection* 19:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Tunnel adapter Local Area Connection* 47:
Tunnel adapter Local Area Connection* 12:
Tunnel adapter Local Area Connection* 39:
Tunnel adapter Local Area Connection* 18:
Tunnel adapter Local Area Connection* 24:
Tunnel adapter Local Area Connection* 15:
Tunnel adapter Local Area Connection* 16:
Tunnel adapter Local Area Connection* 17:
Tunnel adapter Local Area Connection* 22:
Tunnel adapter Local Area Connection* 21:
Tunnel adapter Local Area Connection* 20:
Tunnel adapter Local Area Connection* 23:
Tunnel adapter Local Area Connection* 30:
Tunnel adapter Local Area Connection* 25:
Tunnel adapter Local Area Connection* 27:
Tunnel adapter Local Area Connection* 29:
Tunnel adapter Local Area Connection* 26:
Tunnel adapter Local Area Connection* 28:
Tunnel adapter Local Area Connection* 31:
Tunnel adapter Local Area Connection* 32:
Tunnel adapter Local Area Connection* 33:
Tunnel adapter Local Area Connection* 34:
Tunnel adapter Local Area Connection* 35:
Tunnel adapter Local Area Connection* 36:
Tunnel adapter Local Area Connection* 37:
Tunnel adapter Local Area Connection* 38:
Tunnel adapter Local Area Connection* 114:
Tunnel adapter Local Area Connection* 40:
Tunnel adapter Local Area Connection* 41:
Tunnel adapter Local Area Connection* 42:
Tunnel adapter Local Area Connection* 43:
Tunnel adapter Local Area Connection* 44:
Tunnel adapter Local Area Connection* 45:
Tunnel adapter Local Area Connection* 46:
Tunnel adapter Local Area Connection* 48:
Tunnel adapter Local Area Connection* 49:
Tunnel adapter Local Area Connection* 50:
Tunnel adapter Local Area Connection* 51:
Tunnel adapter Local Area Connection* 53:
Tunnel adapter Local Area Connection* 52:
Tunnel adapter Local Area Connection* 61:
Tunnel adapter Local Area Connection* 54:
Tunnel adapter Local Area Connection* 55:
Tunnel adapter Local Area Connection* 56:
Tunnel adapter Local Area Connection* 57:
Tunnel adapter Local Area Connection* 58:
Tunnel adapter Local Area Connection* 60:
Tunnel adapter Local Area Connection* 59:
Tunnel adapter Local Area Connection* 66:
Tunnel adapter Local Area Connection* 62:
Tunnel adapter Local Area Connection* 63:
Tunnel adapter Local Area Connection* 67:
Tunnel adapter Local Area Connection* 64:
Tunnel adapter Local Area Connection* 73:
Tunnel adapter Local Area Connection* 65:
Tunnel adapter Local Area Connection* 68:
Tunnel adapter Local Area Connection* 70:
Tunnel adapter Local Area Connection* 69:
Tunnel adapter Local Area Connection* 71:
Tunnel adapter Local Area Connection* 72:
Tunnel adapter Local Area Connection* 74:
Tunnel adapter Local Area Connection* 75:
Tunnel adapter Local Area Connection* 76:
Tunnel adapter Local Area Connection* 77:
Tunnel adapter Local Area Connection* 82:
Tunnel adapter Local Area Connection* 79:
Tunnel adapter Local Area Connection* 80:
Tunnel adapter Local Area Connection* 78:
Tunnel adapter Local Area Connection* 84:
Tunnel adapter Local Area Connection* 81:
Tunnel adapter Local Area Connection* 83:
Tunnel adapter Local Area Connection* 87:
Tunnel adapter Local Area Connection* 85:
Tunnel adapter Local Area Connection* 86:
Tunnel adapter Local Area Connection* 90:
Tunnel adapter Local Area Connection* 95:
Tunnel adapter Local Area Connection* 88:
Tunnel adapter Local Area Connection* 89:
Tunnel adapter Local Area Connection* 91:
Tunnel adapter Local Area Connection* 92:
Tunnel adapter Local Area Connection* 96:
Tunnel adapter Local Area Connection* 97:
Tunnel adapter Local Area Connection* 98:
Tunnel adapter Local Area Connection* 99:
Tunnel adapter Local Area Connection* 94:
Tunnel adapter Local Area Connection* 103:
Tunnel adapter Local Area Connection* 102:
Tunnel adapter Local Area Connection* 101:
Tunnel adapter Local Area Connection* 104:
Tunnel adapter Local Area Connection* 105:
Tunnel adapter Local Area Connection* 107:
Tunnel adapter Local Area Connection* 108:
Tunnel adapter Local Area Connection* 106:
Tunnel adapter Local Area Connection* 109:
Tunnel adapter Local Area Connection* 116:
Tunnel adapter Local Area Connection* 110:
Tunnel adapter Local Area Connection* 111:
Tunnel adapter Local Area Connection* 112:
Tunnel adapter Local Area Connection* 113:
Tunnel adapter Local Area Connection* 115:
Tunnel adapter Local Area Connection* 117:
Tunnel adapter Local Area Connection* 118:
Tunnel adapter Local Area Connection* 120:
Tunnel adapter Local Area Connection* 119:
Tunnel adapter Local Area Connection* 121:
Tunnel adapter Local Area Connection* 123:
Tunnel adapter Local Area Connection* 122:
Tunnel adapter Local Area Connection* 124:
Tunnel adapter Local Area Connection* 125:
Tunnel adapter Local Area Connection* 128:
Tunnel adapter Local Area Connection* 127:
Tunnel adapter Local Area Connection* 126:
Tunnel adapter Local Area Connection* 129:
Tunnel adapter Local Area Connection* 133:
Tunnel adapter Local Area Connection* 135:
Tunnel adapter Local Area Connection* 130:
Tunnel adapter isatap.{4C1B5096-F59E-46C4-8252-D824531C5244}:
Tunnel adapter Local Area Connection* 136:
Tunnel adapter Local Area Connection* 139:
Tunnel adapter Local Area Connection* 140:
Tunnel adapter Local Area Connection* 132:
Tunnel adapter Local Area Connection* 142:
Tunnel adapter Local Area Connection* 138:
Tunnel adapter Local Area Connection* 141:
Tunnel adapter Local Area Connection* 143:
Tunnel adapter Local Area Connection* 144:
Tunnel adapter Local Area Connection* 145:
arp -a
Interface: 172.18.242.43 --- 0xe
  Internet Address      Physical Address      Type
  172.18.242.42         64-66-b3-e9-ed-7a     dynamic
  172.18.242.46         00-0c-42-ec-65-c6     dynamic
  172.18.242.47         ff-ff-ff-ff-ff-ff     static
  224.0.0.2             01-00-5e-00-00-02     static
  224.0.0.251           01-00-5e-00-00-fb     static
  224.0.0.252           01-00-5e-00-00-fc     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
route -4 print
Interface List
 37...00 ff 2f d8 de bc ......TeamViewer VPN Adapter
 17...78 e4 00 f1 af fc ......Microsoft Virtual WiFi Miniport Adapter
 14...78 e4 00 f1 af fc ......Broadcom 802.11n Network Adapter
 11...88 ae 1d 05 0c 59 ......Broadcom NetLink (TM) Gigabit Ethernet
  1...........................Software Loopback Interface 1
 22...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #5
 18...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #2
 23...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #6
 19...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #3
 15...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
 28...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #11
 16...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
 60...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #39
[whole bunch omitted due to length restrictions]
158...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #136
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0    172.18.242.46    172.18.242.43    286
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
       172.18.0.0      255.255.0.0    172.18.242.46    172.18.242.43     31
    172.18.242.40  255.255.255.248         On-link     172.18.242.43    286
    172.18.242.43  255.255.255.255         On-link     172.18.242.43    286
    172.18.242.47  255.255.255.255         On-link     172.18.242.43    286
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link     172.18.242.43    286
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link     172.18.242.43    286
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
          0.0.0.0          0.0.0.0    172.18.242.46  Default
nslookup wind.ctwug.za.net
*** Request to UnKnown timed-out
DNS request timed out.
    timeout was 2 seconds.
Server:  UnKnown
Address:  172.18.1.1
nslookup wind.ctwug.za.net 172.18.1.1
Server:  UnKnown
Address:  172.18.1.1
nslookup wind.ctwug.za.net 8.8.8.8
Server:  UnKnown
Address:  8.8.8.8
tracert -d -w 1000 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1  172.18.242.46  reports: Destination net unreachable.
Trace complete.
tracert -d -w 1000 172.18.1.1
Tracing route to 172.18.1.1 over a maximum of 30 hops
Trace complete.
tracert -d -w 1000 172.18.1.11
Tracing route to 172.18.1.11 over a maximum of 30 hops
Trace complete.
tracert -d -w 1000 172.26.66.132
Tracing route to 172.26.66.132 over a maximum of 30 hops
Trace complete.
Not good idea to post you pvt login on an open forum
I can’t get log into any of Nibiru rbs, so I can’t see what the issue is maybe a site reboot would help.
My suggestion would be to scan for @trojan and if the scan results are good ask him if you can move over to his site. He will also advice on correct equipment.
Some captain please explain why IPCONFIG gave him that wall of text on Media State. Pls. Educate me.
Have you never seen something like that before?
Got in touch with Trojan. Teamviewer’ed in. Legend! All good again!
