Help getting my settings in order on SXT
#Problem Description:
Good day.
Can anyone please assist me with my settings. i have tried the wiki but could not get it right. i can pick up my high site. The owner of the high site says he can see im connected but i cannot connect to the form or TT.
if there is anything that i missed can someone please assist me. i would much appreciate it.
also i was previously connected but moved. if there is anything else that i need to add i will do so. hope this thread is in the right category.
Thank you
#Your details:
WiND Node: dean900 #14681
PC IP:172.18.42.25
RB IP:172.18.42.30
#WUG-Check Script output
Download and run wug-check.bat and post the output below between the backticks below:
Start!
2017/11/09
02:40 PM
systeminfo
Host Name:                 DESKTOP-UISE6HV
OS Name:                   Microsoft Windows 10 Pro
OS Version:                10.0.15063 N/A Build 15063
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Standalone Workstation
OS Build Type:             Multiprocessor Free
Registered Owner:          Reaper
Registered Organization:
Product ID:                00331-10000-00001-AA957
Original Install Date:     2017/05/13, 9:56:01 AM
System Boot Time:          2017/11/08, 2:41:42 PM
System Manufacturer:       Gigabyte Technology Co., Ltd.
System Model:              B250M-D3H
System Type:               x64-based PC
Processor(s):              1 Processor(s) Installed.
                           [01]: Intel64 Family 6 Model 158 Stepping 9 GenuineIntel ~3500 Mhz
BIOS Version:              American Megatrends Inc. F2, 2016/11/25
Windows Directory:         C:\WINDOWS
System Directory:          C:\WINDOWS\system32
Boot Device:               \Device\HarddiskVolume1
System Locale:             en-za;English (South Africa)
Input Locale:              en-us;English (United States)
Time Zone:                 (UTC+02:00) Harare, Pretoria
Total Physical Memory:     8ÿ152 MB
Available Physical Memory: 5ÿ786 MB
Virtual Memory: Max Size:  9ÿ432 MB
Virtual Memory: Available: 6ÿ528 MB
Virtual Memory: In Use:    2ÿ904 MB
Page File Location(s):     C:\pagefile.sys
Domain:                    WORKGROUP
Logon Server:              \\DESKTOP-UISE6HV
Hotfix(s):                 3 Hotfix(s) Installed.
                           [01]: KB4022405
                           [02]: KB4049179
                           [03]: KB4041676
Network Card(s):           1 NIC(s) Installed.
                           [01]: Intel(R) Ethernet Connection (2) I219-V
                                 Connection Name: Ethernet
                                 DHCP Enabled:    No
                                 IP address(es)
                                 [01]: 172.18.42.25
                                 [02]: fe80::d0c:9d0e:42bc:12e0
Hyper-V Requirements:      VM Monitor Mode Extensions: Yes
                           Virtualization Enabled In Firmware: Yes
                           Second Level Address Translation: Yes
                           Data Execution Prevention Available: Yes
ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::d0c:9d0e:42bc:12e0%12
   IPv4 Address. . . . . . . . . . . : 172.18.42.25
   Subnet Mask . . . . . . . . . . . : 255.255.255.248
   Default Gateway . . . . . . . . . : 172.18.42.30
arp -a
Interface: 172.18.42.25 --- 0xc
  Internet Address      Physical Address      Type
  172.18.42.30          00-0c-42-e0-3a-38     dynamic
  172.18.42.31          ff-ff-ff-ff-ff-ff     static
  224.0.0.22            01-00-5e-00-00-16     static
  224.0.0.251           01-00-5e-00-00-fb     static
  224.0.0.252           01-00-5e-00-00-fc     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
route -4 print
Interface List
 12...1c 1b 0d a9 55 31 ......Intel(R) Ethernet Connection (2) I219-V
  1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0     172.18.42.30     172.18.42.25    291
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
     172.18.42.24  255.255.255.248         On-link      172.18.42.25    291
     172.18.42.25  255.255.255.255         On-link      172.18.42.25    291
     172.18.42.31  255.255.255.255         On-link      172.18.42.25    291
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link      172.18.42.25    291
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link      172.18.42.25    291
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
       172.16.0.0      255.240.0.0     172.18.42.30       1
          0.0.0.0          0.0.0.0     172.18.42.30  Default
nslookup wind.ctwug.za.net
*** Request to UnKnown timed-out
DNS request timed out.
    timeout was 2 seconds.
Server:  UnKnown
Address:  172.18.1.1
nslookup wind.ctwug.za.net 172.18.1.1
Server:  UnKnown
Address:  172.18.1.1
nslookup wind.ctwug.za.net 8.8.8.8
Server:  UnKnown
Address:  8.8.8.8
tracert -d -w 1000 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1  172.18.42.30  reports: Destination net unreachable.
Trace complete.
tracert -d -w 1000 172.18.1.1
Tracing route to 172.18.1.1 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  172.18.42.30
  2     4 ms     3 ms     3 ms  172.18.43.250
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
tracert -d -w 1000 172.18.1.11
Tracing route to 172.18.1.11 over a maximum of 30 hops
  2    13 ms     5 ms     5 ms  172.18.43.250
Trace complete.
tracert -d -w 1000 172.26.66.132
Tracing route to 172.26.66.132 over a maximum of 30 hops
  2     6 ms     2 ms     6 ms  172.18.43.250
Trace complete.
Done!
2017/11/09
02:45 PM
Hi @dean900, I logged into CapeFlyer-Omni2 now, your routing is correct on that device. I also logged into your SXT from there and your routing is also correct on there.
This is a IP forwarding issue @capeflyer beyond his Omni. More than likely from the Core RB that is forwarding his IP’s to his Omni.
Also, please avoid Quickset, it has a nasty habit of breaking your Wlan route.
Here is your problem by @capeflyer
That range forwarding needs to be enabled and the comment needs to be updated.
@dean900, have a look now. I fixed above mentioned route and comment.
thank you so much @Firestarter will have a look tomorrow morning when i get home from work. Thanks for the help again. Much appreciated.
Can I just say that you win the prize for the best support request ever!!! Very impressed.
I agree @spin thank you so much for fast reply and help. Much appreciated @Firestarter.
The thread can be closed thanks again
@dean900, Spin was refering to the way you posted your support question.
Well done, made it much easier to troubleshoot.
