This link works perfectly. If you are keeping track of the ips all you do is use the ip after previous address broadcast address (depding on your assigning could be ip address after network address)
Example if the last ip set you used ended 18.18.126 making 18.18.127 its broadcast eneter 18.18.128 and do a /28 calculate and should give you the result you looking
@Firestarter made a Spreadsheet that apparently does all the calcs . The thread had to do with “adding someone to your sector” howto. Have you tried that?
Hi Gekido, for example, if the next available range starts at 149.200 and I make it a 149.200/28 would that range consist of IPs from 149.200–149.213 ? being between the skipped 149.199 and 149.214
I saw that but because the network IP is 192 (which I already reserved as a 172.26.149.192/29) and the next available range after this would start at 200. is the confusing part. I thought that the /28 would continue like the /29s and just use 14 IPs instead.
