Is Epsilon Down?
Hi Guys,
I know wind has been hectic down this side, I want to know if Epsilon is down, or if the wind has buggered up something on my side, Have not been able to connect in over 2 weeks now.
Looking forward to hearing from you guys!
Epsilon is up and running normally. I see you’re connected although the signal is so bad that you might as well not be. Try hop up on your roof and re-align again.
Pvt/Email me if you need help so that I can send @sharkie
King you closer to op on his roof…
Thanks Guys will get up there on the weekend and see what I can do.
By the way who do I contact about the AGM at the end of the month, looking to sponsor some custom made acrylic trophies if you guys don’t have anything like that.
I think @Committee ,
I send you a mail at 19h46
