Mikrotik Help for wireless network
Hi all,
I am not currently part of the CTWUG, and apologize for posting this here. However, I am trying to set a up a wireless network for the residential complex where I live.
I require some help in configuring my Mikrotik Router - the network is running, just experiencing some teething problems which I was hoping maybe some of the MT experts here would be kind enough to assist me with? Is there anyone I can contact?
Thanks in advance.
Hello
Could you describe the problem that you require help with?
Post here is the best. Then you can get many eyes instead of one.
Perfect. Thank you!
At the moment I’m having a problem with my MT dialling PPPoE to my ISP.
When I set up the configuration, it works. After a while the PPPoE client says “Link Established” instead of “Connected” and clients are unable to access the internet.
Running a PPPoE server on the MT, with Userman for client management, Ubiquiti Bullet M2 as wireless access point.
FYI:
Sounds like a handshake issue…
The following post sums up the issue that may help resolve your situation;
http://www.dslreports.com/forum/r19381166-MTU-MRU-problem
Thanks speedS.
However, my problem is not with the clients. The clients remain connected, but the pppoe interface does not connect. Any ideas?
