Hi guys i haven’t been online for a long time and i am having some troubles with bad connection to wolfie, i have scanned and it looks like Tubby is pretty good at -59 but i am still new to the wug and networking so any help would be appreciated
i can see my RB is on the light is on, but i am unable to connect to it and its not in my neighbors list either, but when i ask bottie to ping my rb rb.lemonxah.ctwug.za.net (172.26.31.22) its up but i am unable to connect to it?
Its like the lan port is disabled on the device, its unreachable so i am offline
thanks but i got it working again had to take down the rb, someone logged in at 1am and disabled the lan had to reset the device working now and i disable all the accounts and changed all the passwords, unfortunately the logging was memory not disk so i dont have the ip of the person/ persons accountable
Thank you wolfie i did not want to inconvenience you in any way, its a drag climing up a tower all day long But thank you for the concern and if i had known i would have given you a call but its been about 2 years since i really used the wug an i didn’t what has changed in that time
