Nemesis (mostly) down
Nemesis site is sort-of flapping a bit, with the device that is doing the advertising for 172.26.22.0/23 doing the ups & downs. Prior to this starting I have had a discussion with Ogon as to the decommissioning of this device, so this is only pushing the timetable a bit. Please bear with us for this, work life is a bit hectic.
In the near future we would also do a site visit for the planning of and executing a revamp of the site, which would results in downtime as well (at least this one would be planned downtime)
ek moes my link ook disable na nemesis toe sien is sleg was in die -80 gister middag toe weer -62 moet nog kyk waar le die probleem nou gekyk nou wys dit weer reg :astonished:
Was dit sleg net na reen?
die link was ok gewees die heeltyd even na die reen. :slight_smile: dit het net randomly begin ek het ook nogals gedink aan die water die goed is gebytyl tape en met insulation tape toe gemaak nie te lank terug nie paar maande maar gaan kyk later of dit nog mooi toe is
