New Node in Welgmoed need Test Kit scan
Hi,
I need to do a test scan at 72 Gazania Street with the Test Kit, can somebody help?
Pieter
0828220309
pieterh54@yahoo.co.uk
Hi Pieter, have you plotted your home on wind.ctwug.za.net yet?
If so what is your node name?
Ok I have plotted a test node https://wind.ctwug.za.net/index.php/nodes?node=15658 as I see it hasn’t been done yet. It seems like you have Excellent LOS overlooking the entire Tygervalley. @Diabolix we might be able to split @Wacko141 - Europa here.
I don’t believe I can see that low down on the hill :confused:
We need pictures from your roof top in 360 degrees please :slight_smile:
Hi All,
Seems WIND is down, but I think my node name is Fightclub, I’m on the hill, back yard looks over willow bridge and tyger valley. Don’t have pics now, will take them tomorrow and post a link to google drive.
Wind is running:
Don’t know why, but can’t get to WIND, all my other sites are fine, see you found my node, thanks
Managed to get in this morning:
Skramrox seems like the logical choice at the moment, But as Diabolix said, "We need pictures from your roof top in 360 degrees please "
WiND is down if you repeatedly (6 times I think) login or try to login inside 10 minutes. If you do this your IP will be blocked for an hour and you won’t be able to access anything on that server.
You can post pictures on WiND directly. It’s useful as you only need to do this once and anyonce can go and check out your LOS. Like so:
Even better:
You can also directly paste a photo directly into a post here. Far easier for all than everyone clicking links. It also means that the picture is stored with the forum so we don’t end up with broken links down the line.
