Pmurgs-Helderberg shifting
@pmurgs
The link between pmurgs and drakehome was disconnected last week as the equipment had to be removed from the drakehome node.
I am in the process of collecting the equipment and need to scan from a different node to get the pmurgs-helderberg link going again.
I hope that you could accommodate us with test scanning and aligning the dish on your side to the Gordon’s Bay area again. The new node will be The Vault (#12829). I should hopefully be doing a test scan this Thursday if possible that is.
If you could let me know if this is in order.
Much thanks
cAfstA
Hey Cafsta.
That kit is mine, at the drakehome node which connects to me, which you removed, but… all good (with reservations till we see this through), ok, I’ll try align to The Vault.
Peter (pmurgs)
Hi pmurgs
I did not know it is yours but I do have it at home with me and can return it to you. I have the two 31dbi grids, you just need to let me know if the rb and radios (how many?) are yours as well.
Thank you for accommodating us with the realignment. It’s much appreciated.
cAfstA
The girds, the rb, the card, the lmrs, the ut7 or is it one of those other one with the hex screws, cant remember. All in that single link, is mine.
No worries with moving it. All good with me. It’s mine, but its there to make a link :slightly_smiling:
I should come out and see The Vault sometime and meet the owner, who will be hosting my kit.
Old the old kit including yours was removed as they upgraded to dishes.
Yeah uhm. Ok. But stuff still belongs to me. So… where do we stand on that? Was rb433ah with r52Hn and with 31 grids and enclosure. Grids no big deal, but rd and radio card i still consider mine which i want ownership of, or want back.
Yeah no problem pmurgs.
All of the above is with me. The enclosure though is not able to close though as the bolts could not be loosened when we took it down so it has broken off in the holes.
Anyway I have the items in my possession so it just needs to get to you.
Ok, give me a sms on 082 7887097 and perhaps I’ll fetch them Sunday around noon if thats good for you.
