Protea Valley/Welgedacht
Hi,
The Giftand-JypelsOude link is now live.
This provides the following redundant path:
Europa(10)-(10)Wacko141(10)-(10)Giftand(5)-(5)JypelsOude(10)-(10)Skouperd
Still left to be done:
  1. Giftand-Poseidon (Should be up tonight)
  2. JypelsOude-Moontop
I’ve just moved to Protea Valley and looking for a new connection.
I currently have a 27db grid and rb433 kit (the old scoop kit).
I am willing to upgrade my kit if my location will benefit the area. My node is heist #4329.
If not, a preliminary scan(just held the kit in general direction) to kaarkie looks promising at -71.
Once mounted on the roof that should be in the -60 to -70 range.
So is that my only option, or can you guys suggest something else?
Heist, come chat to us in IRC :slight_smile:
#ctwug-bellville
Hi Hesit,
I just had a look at your node. You will definitely require a dual polarization kit in order to connect to Kaarkie, as the sector is mimo.
Also, I would recommend a dish and Mikrotik netbox/basebox for the connection. As we only allow SXT’s for distances shorter than 1km.
So here are the photos from my roof.
First one from the most western point on the roof:
Now one from the most eastern point:
So as the photos are not very clear, I borrowed a pair of binoculars and I def have a clear LOS to kaarkie.
As for a new kit - is this sufficient?
http://www.scoopdistribution.co.za/product_info.php/mikrotik-30dbi-dish-antenna-p-1673
and
http://www.scoopdistribution.co.za/product_info.php/ros-600mhz-64m-1xge-1x5ghz-1xm-pcie-p-1462
anything else I should rather be looking at?
Hi Heist, my suggestion is that you first borrow either an SXT from me or a dish kit and do a test scan.You really dont want to buy equipment and find out that for some or other reason you cant get a stable connection. But yeah the 30Dbi dish and the Rb912 you have listed works a treat :slight_smile: have the same kit between me and skouperd and pushing some great speeds…Would you be connecting to the kaarkie sector or adding new kit by him?
Hi Jypels
I have an SXT that I can borrow - thanks for offer.
For the sake of a scan, will a mimo kit be that much different than a single polarity kit?
I guess I’m hoping to connect to the sector if there is space for me though I’m open to any other link suggestions.
I Just think if you going with a 30Dbi dish and an RB912 that has an gbit port and 300mbps capable, you’ll be seriously hampered connecting to a sector with alot of users on it… might get 2MBps if you lucky. Rather connect to a dedicated AP. I would also recommend you go with a 23dbi dish if you can source one as distance is so short
What about a nanobeam or something? The distance is short and 30dbi might be a bit overkill?
That being said, im not sure how micro <-> ubiq will work?
Easy, it doesn’t work :slight_smile:
Heist, the kit you listed is perfect that will make sure you have a proper connection.
Awesome thanks. I’ll go ahead and order it so long.
Just a quick thanks to all working on the wug connection in this area (Diabolix etc.) . Connection is stable and speeds are awesome !! Thanks guys (and girls if any)
