Hi gents I have a rb750 my wug and internet is plugged into it but my wug alone is active how do I get both of them to workh and to shared internet at the same time please can anyone assist me
Hey Donutpeach
There is three easy steps to achieve this, first you need to know what the ip of your router is that dials your internet.
Tenda are 192.168.1.1
D-link are 10.0.0.2
This is what I do to get the internet working
- I add an IP in the same range as my internet router(d-link) and forward it to the ethernet port that its connects to. My RB750 is setup as a switch with ethernet 2 as the masterport.
ip address address add=10.0.0.100/24 interface=ether2 comment=“Internet”
- Now I will add a route to the internet and forward it to the D-link router
ip route add dst-address=0.0.0.0/0 gateway=10.0.0.2 comment=“Route to internet”
- Add a default firewall
ip firewall nat add action=masquerade chain=srcnat
If you type those three command into your terminal of your RB750 your internet and your wug should work together.
I’m assuming that your rb is setup as a switch and that you master port is named ether2
