Rhea routing problem?
I connect to Kingpin, but I am not able to route to 172.18.1.1 or any other network for that matter. Is anyone aware of a problem on Kingpin?
A little searching goes a long way :stuck_out_tongue:
https://forum.ctwug.za.net/t/rhea-hs-seems-down/7198/10
P.S Welcome out the woodwork, Kingpin is now called Rhea and has been for ages
Thanks Zassie, I don’t seem to have access to that forum though. Access denied.
That is because you are not a Active Wugger on the forum
I thought as much yes. Can you perhaps share the info of the thread? Any idea when the routing problem on Rhea will be resolved?
Soos ek jou reply het op die chat groep.
Thank you Spaffy. Appreciate it.
Please post in support for support queries.
