Hi there,This is Praxus (node 1295) connected to Rhea on the 5ghz sector, Rhea seems to have dropped off the network My RB is just scanning since 15:08 8th Dec I can still see shadow at the same db as normal so i know the rb has not moved ( LHG ), does anyone know whats going on ?
RB IP 172.18.16.30
PC IP 172.18.16.29
Hi i have noticed the issues started about 2 days ago already since this is our only link into kfn
Hi Razor, thanx and oops, I assume you don’t know what is wrong yet and i can also infer that it is not only the sector.
Kind Regards
Mark
I remember Hunted contacted me regarding Rhea I think they wanted to discontinue the site.I gave him @coms number.
oh dear some more bad news for the wug
very sad indeed, like damn more people need to get involved else this forum might no longer exist in the near future
If Rhea is going down permanently I may be able to help out if you have LOS to my tower and if your signal is good.
Hi there Shadow, I can see shadow 8 @ -78 noise -111 but I am still aimed at Rhea, pls let me know if i can join and what I would need to do.
Kind Regards Mark
No problem Mark. I’ll send you a PM. We can take it from there.
Hi Shadow. This is my first post. I lost connection a while ago. Please will you be able to assist me getting connected. Manne #11779
Hi @manne you are even closer to me than you were to Rhea. I am sure we can make a plan. I will send you a PM.
