In the last week we had another security incident on the WUG. To this end the committee has decided to implement the following:
- Automatic blackhole for repeated login attemps on any router running radius. Most likely this will be something similar to 6 failed logins within 10 min from the same IP to any radius router. This is likely to lead to 24h blackhole and later a permanent blackhole with investigation if repeated
implemented here. - Removing all accounts
adminwhere no password exists from OSPF routers. Perferably all routers. To this end you are unlikely to see login attempts from @dizzle for this on your routers. Please ignore this. - I will also make it easier to keep wug routers up to date in terms of firmware.
- Update minimum RouterOS versions
implemented here.
Please please please run proper firewalls on your internet routers. Keep them up to date.
