Hi
For the last couple of weeks I’ve been experiencing very slow speeds. My signal strength and settings are unchanged. I was just wondering if there are other wuggers on Venus also experiencing this.
Mookey what is your CCQ and sync rate sitting at?
my ccq is fluctuating on the low side. don’t know what you mean by sync rate.
Sync rate : 120mb or 6mb
What are the figures?
28.8Mbps/6.5Mbps also not stable
And your ccq?
28/21 at best
Sheesh. You’ll need to realign. Those are very low. Do you remember what they used to be?
unfortunately not . I just know it was better than the minimum recommended on the wiki
Okay. Well you going to have to climb on your roof and sort things out. Only way you going to improve your speeds.
thanks for the help.
Yes, please realign and test again as with your current connection you will be impacting all the other clients on the same sector as you.
I will have tomorrow.
