I will building my smart home system soon and will post updates and let everyone know about the build planing to use smart things API as well as Google Assistant API. Thank you
I also looked into the Sonoff smart switches and as was actually looking at the quikswitch which does the same. Reason I was looking into it was i have two geysers and wanted to put a smart switch in them to control the temperature on them. But this would not work on the Geysers.
Just remember that Sonoff only has 10 & 18 AMP switches, so pretty much only for lights unless you run one cable per switch. I’m looking to buy a bunch of them as well since I run Google Home in my house (Google Hub, Mini, Chromecast, Audio Cast, Roku, General Electric smart bulbs, etc) that I want to integrate.
Also bought a load of ESP32-DEVKITC boards to put into the loop.
Im looking for a nodeMCU v3 but for the love of myself cannot find a trust worthy supplier its VERY similar to what you got there but need it to be a nodeMCU V3
Hi Guys
U can get some of them here also
Dont know if you saw these. Seem reasonably priced
Ok I drifted a little Im looking for someone who can print and make a circuit board for me to complete my home automation.
If here is anyone who can help print 1 or 2 circuit boards please?
Contact Tangmonster he might be able to help you or at least point you in the right direction for PCB’s
