Was wondering if anyone has been using the Sonoff smart switches in their home network especially the garage and light switches.
What are they like?
Are they user friendly?
Does it come with an app for Android?
Can it be controlled from anywhere or is there a port forwarding requirement?
Does the garage door opener also use short range wireless to open it, not just the app?
There’s a pile of videos on YouTube regarding them. Also if you wish to be more basic, look at the ESP8266 chip.
I have not personally used either, I am just interested in a Home Automation setup for my house and at the research stage.
OK, I think I will go ahead and purchase one there is one where a guy hotwires some remotes into the cuirtcuit and configure it with google home and alexa. it worked Flawlessly so having an existing garage motor ect intergration is easy.
Yep i use them, got 3 of them now one on the pool, one on my rain water, and one that ran my xmas lights. will be reusing that one for some thing i have not thought of yet. pretty easy to setup and app is basic but effective.
i also have been using the sonoff switches works great easy to setup and no port forwarding needed. Even bought some on wish for like R70 they also work fine
Needed some quick at the time, thus the sonoff, must say i am happy with
the the performance it does exactly what i need them to do for me.
only gripe i have is the app, though it works and does as it should with no
trouble. me being a techie would have loved more from it.
some sort of better dashboard to manage multiple switches, see what they
are doing manage them and see the power consumption that goes through
them… but thats just me.
you can get them from communica in Paarden Eiland they also work well with home assistant if you flash the firmware with Tasmota a very useful bit of software see DR Zzs on YouTube for more info on Tasmota.
I currently use three sonoff basic switches and control them via the android app. It works well as advertised. Only issue is they require an active internet connection to operate, especially if you schedule the switches to switch on or off at certain times. I bought mine on gearbest for ± R80 each. Look for their flash sales.
They are great little devices, do exactly as intended. If you do not like the internet requirement, they can run 3rd party firmware where you can setup your own MQ server.
