SXT Lite Help (Business related)
Hi Guys,
Wondering if anyone can help me.
I need some assitance with a point to point link that i installed at Saxenburg Park 1.
The link where already setup by the supplier i just installed them, my wireless knowledge is extremely limited and i cannot get a stable throughput rate.
Can anyone recommend someone i can call to help me fine tune the links? it was for a business so willing to pay for the time.
The basics are as follows:
-4 SXT lite units in bridge mode, so two of them are on one pole as there is no line of sight.
  • its transmitting one IP PTZ camera back to a recorder
  • total distance cannot be more than 2km
    -signal strength is between -56 and -63
  • CCQ is not good and not stable at all
Hope thats enough information for someone to point me in the right direction.
Regards
Gershwin
on our own network we don’t recommend a sxt for a connection above 1Km , have had way to many problems trying that.
I would recommend you replace the sxt whit a LHG5.
that is the thing ON OUR NETWORK nothing to do with his setup 2km is still ok i have seen links longer working perfectly fine with sxt’s it probably needs proper tuning like frequency,protocol,data rates and so on
@razor1 is my suggestion at all unfounded is a LHG5 not better than a sxt in every possible way. Is anything I said untrue ? It was just a suggestion @Hello can use it or not.
Hi Guys, no this is not on the WUG network, its for a business.
The links where purchased buy the client and the supplier set them up, i just installed them
Gershwin
