toekies:
Hi Diabolix
Only saw this message now. Tried to mail you.
I want to be reconnected. What do I need to do? I dont have a SXT but a grid.RouterBoard Groove 5Hn
5.1-5.8GHz 24dBi Grid Antenna. Should I change the info somewhere?
I mailed you a pic of my equipmetn, but its a grid up to 5km I think.
not to clued up with all of these things
Hi Toekies,
You would need to upgrade to a MIMO kit.
My suggestion is the following:
http://www.scoopdistribution.co.za/product_info.php/ros-600mhz-64mb-1xge-1x5ghz-p-1647
This should be more than sufficient.
When you are done, just email me your new wireless MAC address. Then I can add you.
Thx Diabolix
Will look in doing this as soon as possible.
Would i be able to connect to another with this equipment RouterBoard Groove 5Hn
5.1-5.8GHz 24dBi Grid Antenna?
What is the difference between MIMO equipment and SISO?
Thx Diabolix
Will get it sorted as soon as possible.
what is the difference between that equipment and the one i have, RouterBoard Groove 5Hn
5.1-5.8GHz 24dBi Grid Antennae? Sorry if its a stupid question.
toekies:
Thx Diabolix
You won’t be able to connect, as the upgrade notice was sent out 6 months ago for clients to upgrade to MIMO equipment.
If you want, you can ask for a extension by the committee till the end of this month (With a good reason).
Video on MIMO vs SISO: https://www.youtube.com/watch?v=ZNfzBwIDcZY
Spaffy
August 11, 2015, 8:12am
45
toekies:
Hi Diabolix
Hello toekies, and welcome to the forum.
toekies
August 13, 2015, 12:52pm
46
Thx Spaffy
@diabolix , got it, will install today and get back to you.
thx
Cool, just give me a shout tonight in the #ctwug-bellville IRC channel.
Hi Diabolix
My MAC address is 4C:0C:8C:E2:99
I did a copy and paste on all the router info/settings, if you can please double check that all is correct.
thx
Hi Diabolix
Just want to know if you had time to see if you can reconnect me?
Give me a shiut if there is anything I need to do from my side.
Thx
toekies:
Hi Diabolix
thx
That is too short for a MAC address.
Waiting on IRC for you.
@Diabolix ,
please enable me on titan1 (bellville sector) please.
i am running mimo hardware now.
the current setup is only temporary. still waiting on my m-pci card to be delivered.
so i spoofed my old mac on the current temp equipment.
will send you mac address of new radio as soon as i get it.
Thanks in advance bud.
