Ubiquiti long range Ap
I need some advice from all the techs.
I installed an access point as per topic to my Tenda Ac router and just changed the ssid and password on the ap, connected it, and its working well. But I need to switchy wifi on and off for it to connect to the ap.
Is there another way of automatically connecting to the ap ?
Thx Shaun
Hi Shaun might be a channel issue. Did you do a scan to see if there are any others aps running on the same channel?
Thnx @MDE ill try and figure that out . Got another tenda extender on the other side of the house. And check that one too.
