so i currently have 2 networks running NETWORK 1(internet) and NETWORK 2(WUG) i would like assistants to run these 2 together please,i saw a similar post but im not sure if there is a different process for the service provider
please anyone
please anyone
just to confirm… you have 2 NICs. one for the wug and one for the internet.
setup the wug NIC with a fixed IP, make sure you can ping your router(RB).
open an administrative command prompt and type:
route add 172.16.0.0 mask 255.240.0.0 [your RB IP here] -p
This is on a windows pc ofcourse.
thats all. job done
I had the same problem, I ended up buying a different router, the router has some type of Firewall rule that you cant turn off
i dont understand why you would want to join the two networks just to route wug traffic to a seperate router unless you are nat-ing your wug ip to your local (b315) ip range.
@FROZEN-SHOT if you want me to teamviewer and have a look for you. just lmk
My contact (WA) details
