Virus - SMB Port Scanning (Wannacry?)
More popped up:
172.18.115.71 - noname.bouncer.ctwug.za.net
172.18.32.35 - pc3.randal.ctwug.za.net
whats up with this > noname.bouncer.ctwug.za.net even if you do nslookups that name pops up under the DNS server
This should be fixed now, he for some reason added the DNS server IP as his own IPs.
This ip appears to be reinfected. Been on here before. One of @Ironman clients?
We also had other infections from this node. If people clean their pcs they need to clean then all and patch/update them.
172.18.115.71(LABIMAGE - DNS TAG) is still trying to spread the “Wannacry”
It does seem to be a device on the Snot #8736 subnet.
I see my IP 172.26.60.132 got blocked again. I did scan with Malwarebytes and Microsoft Security Essentials and no virus was found.
Can somebody please tell me what should I be looking for to get rid of this pest. Or what to use.
Hi. I did install Kaspersky and did a full scan. I did find 38 pests but cant tell if it was the right ones. Can you please unblock
my Ip and see again whats cooking?
THX
@spin
All cleared up on my side, could you kindly unblock.
thank you.
@spin
@dns:~ $ nslookup 172.26.137.146
Server:         172.18.1.1
Address:        172.18.1.1#53
146.137.26.172.in-addr.arpa     name = pc2.mafia.ctwug.za.net.
I’m a bit behind with this. I will clear out the list of blocked IPs and we can see what we get. Haven’t had anything on my firewall in some time.
Only been seeing 172.26.137.146 in the last 24 hours.
OK updated block to only that IP and updated first post.
@spin
@Adriaan 65.13.26.172.in-addr.arpa name = adriaan1.adriaan.ctwug.za.net.
@blinksnode 229.31.26.172.in-addr.arpa name = stinge-pc.blinksnode.ctwug.za.net.
@Smurf 2.153.26.172.in-addr.arpa name = pc2.smurf.ctwug.za.net.
@redrbk 180.27.26.172.in-addr.arpa name = stefpc.redrbk.ctwug.za.net.
@Mafia 146.137.26.172.in-addr.arpa name = pc2.mafia.ctwug.za.net.
Morning @spin, will fix that pc this weekend 172.26.27.180
Yes @spin PC2 smurf 153.26.172.2 scaned and virus removed
I’ve added automated protection for SMB scanning (updated first post). If you scanning on such ports you are either infected by a virus or trying to find insecure shares. Either way you will be blackholed.
@dribbel and Randal you guys have infected hosts. I’ve upped the block to 7 days by default so next time your PCs scan they will be blocked (or I’ll block you manually if I can).
@dribbel please fix your host. rb1.dribbel2.0.ctwug.za.net / 172.26.151.214 is infected (probably a PC natting on that IP). @Naruto can you please disable route/link to @dribbel until his PC is cleared out. Can’t login there myself.
Randal connects on Cyprus that connects on @TheStalker . Can someone contact him. I’ve disabled his route.
pc1.randal.ctwug.za.net / 172.18.32.33 is infected.
Hi. Wat is dit? Wat kan ek nou doen?
That is infected with some virus.
