WIFI and WUG together
Hi Wuggers
Can anyone assist me how to get the two buggers work together
With thanx
Smurf
Soooo much info to work on here!
https://wiki.ctwug.za.net/wiki/Internet_and_WUG_Routing
Vodacom Mobile WiFi and CTWUG
Hi Smurf,
Generally these devices do not allow you to set up static routes, as the Service Providers lock it down in their firmware versions.
1st prize would be to add a static route for 172.16.0.0 with subnet mask of 255.240.0.0
if you are not able to do this, you would need to disable the wifi on the Vodacom router and purchase a device like the HAP Lite or better. With this you would then connect the VC Router and the Router connecting to the WUG. This would also then do your internal Wifi
Thanx Buddy JelleBean
Please post these kind of requests in support. I’ve moved it now.
