How can I join and get hooked up. I’m a newbie and need help from scratch. Thanks in advance
hi there https://wiki.ctwug.za.net/wiki/Start_Here and if you need further help shout.
Hey @Sirus,
Welcome
Above is the getting started guide, follow that and plot a Node for yourself on wind.ctwug.za.net. Once that is done reply with your Node name and someone will be able to asssist.
@wakkie, think we replied at the same time.
Thanks @wakkie and @Firestarter I have a node, Sirus so what’s next
Is this you @sirus?
@Firestarter yes that is me
@Snow.com is the FirstContact for that area, he will be able to guide you further. I am not familiar enough with those sites to properly guide you. I would however suggest that you book the test kit and do a scan to see what you pick up.
@Firestarter thank you and @Snow.com how do I go about booking a test kit.
There is the guide ![]()
Thanks @Firestarter. I have read the guides and thing but it’s always better to talk and get clarity. You are awesome help. #HangLooseBuddie.
. @Gekido I would like to book a test kit?
Hi
Waar is jy. Is jy al op wind.
Danie
Ek is in wesbank en is op wind node name Sirus #16705
Not trying to be negative but where he is “is n gat” going to be very hard to connect him unless we kan get a HS by him connecting to gants centre. @Sirus I don’t think he will see you as he is really " in n gat"
Hi here is my node name and number, Sirus #16705. What equipment would I need.
Have you booked the testkit?
After doing the scan then only can you see which equipment you need.
Also if you read the Getting connected it says:
DO NOT PURCHASE ANY EQUIPMENT WITHOUT KNOWING EXACTLY WHAT YOU ARE BUYING AND FOR WHAT.
Under no circumstances will CTWUG be liable if you purchase equimpent you can’t use or that is incorrect for your use. It is solely your responsibity to be 100% sure before buying anything.
@Sirus just create one thread instead of replying on multiple threads on the same topic plus PMing me three times in a row.
@Lifepuzzler I did not book it yet. I am waiting on @Gekido as I think that’s the nearest contact to book one by.
Hi @Coms I see a few back bones around me. Will that help me when I do the scan once I booked the test kit and did the scan?
Maybe a PtP -> DeaneTowers can be an option?
