Need help setting up and connecting to CTWUG
Node: Yasin’s WUG #16551
My hardware: MWEB Fon router
Sort of read through getting started guide, yes
I need help setting up and connecting to CTWUG network, please:)
Hi jnsyas.
Suggest you read the getting started guide properly.
https://wiki.ctwug.za.net/wiki/Start_Here
Then book a test kit.
the mweb FON router will not connect to the WUG.
Contact these nodes as you have line of sight to them.
Dan
KMairwolf
Hope to see you connected real soon
Thanks for the response. I’ll check it out. Forgot to mention that I also have a mikrotik router board os AP.
KMairwolf is getting taken down so you will have to see what other options are available to you.
What model Routerboard? An indoor unit? If yes, that wont work either.
Yep, it’s an indoor access point
@jnsyas, check out the following forum post: CTWUG Test Kits (Official)
That is how you go about arranging the CTwug test kit for scanning purposes. The person who gives you the test kit will be able to explain to you what needs to be done, alternatively post here and someone else will guide you.
Thanks. How can I contact @Ogon to book a test kit, please? I’m new to this forum and struggling to find the option to PM.
@cheaptrick, has the test kit for Parow area. Lets wait for him to respond on this forum.
Test kit wiki says @Ogon manages the one for Atlantic seaboard. I’d like to connect in Woodstock.
@jnsyas you can whatsapp/mail me to book test kit. mark@zsd.co.za or 082 956 9698 thanks Mark
