Hi anyone I wanna set up antenna connect to the ctwug group need to buy equipment and if someone can help me get connected please
You need to start here > https://wiki.ctwug.za.net/wiki/Start_Here
Please follow our getting started guide before buying any equipment.
Jy is darem vinnig ![]()
Had someone that offered me a link and a space on his pole I got my user name already need equipment not really know what to buy and setting things up
Still have to familiarize myself with the way wug works and how to go about things
Razor thank you for replying I have read it through also have a nod already and I need to connect to my excess point with equipment that I must still get not really know what to get and where to buy it from
Go through the process.
Book a testkit and GO THROUGH THE STEPS TO GET CONNECTED.
Or speak to [quote=“Edries1, post:5, topic:11749”]
[/quote].
Problem solved.
Best is to speak to the owner of the node u want to connect to because not all the sites use the same equipment some uses mikrotik others ubnt. The owner usually have to tell you what to get since they manage it and they know what type of link will be made when u have that info then you can get the correct equipment by using this guide > https://forum.ctwug.za.net/t/ordering-from-scoop-the-full-monty/8020
Thank you so much that was very useful at least now I do get the know about it now.
