Hi Guys,
With reference to test kit post -CTWUG Test Kits (Official)
I have decided to create a post for booking out the kit. Which will make things much easier if anyone wants to know if the kit is available or not as i will post on the forums who has it and the timeframe they will have it for.
Areas that are covered
Belhar/Delft/Helderberg/Kuilsrivier
Test kits are booked out for a maximum period of 7 days, please return sooner if possible. If not returned after 14 days, you accept that CTWUG can replace the test kit in full for your account.
Test kits consists of:
*** 1 X LHG5**
*** 1 X telescopic pole**
*** 1 X CAT5 cable**
*** 1 X PoE injector**
*** 1 X 24V 0.38A AC adapter**
Things to check when you take/return a test kit:
*** All components are present**
*** The test kit is 100% operational with no physical damage**
If you would like to book out the test kit. please post on this forum post that you would like to bookout kit then copy our terms and conditions below and agree to it in this post.
See example below :
Terms and conditions
*** 1 X LHG5**
I agree to the terms and conditions. I would like to book out test kit.
Node name : type in your name node.
Additional how to register a node on wind : https://wiki.ctwug.za.net/wiki/Getting_Started
How to purchase kit once testing is done : Ordering from Scoop - The full monty!
Thanks In Advance
RMX
