we are going to upgrade Titan tomorrow at 2 in the afternoon, any help will be appreciated, meeting place is at Labiance Towers in Stikland at 1:30 pm at the front gate.
please inform Diabolix or PollyG if your interested in assisting us, help is needed.
No sure guys, thanks thou for thoughts but Titan has been upgraded, so
we are waiting for Diabolix to do finish with the routing en so on, thanks anyway
Titan was a successful install/upgrade. We have a main router (RB2011L) doing all the routing between each other. For the links part, it goes as follows: One backbone facing towards Alfa (On bottelary). One facing towards LockJaw. One facing towards Bellville which will most likely connect to Nitros or SAPolisie.
Then we have a sector facing towards Brackenfell, with the aim of helping out some new wuggers and helping with load on Saturn. SSID: http://ctwug.za.net/Titan1
Helpers includes:
-PollyG
-ToyBoy
-Ford
-Spike
-Sabie
-SAPolisie
This install happened on Sunday (in the storming rain). So thanks for everybody that helped.
Some pictures after the install, in more suitable weather conditions.
P.S We only had permission for one pole. So we tried to squish in as much as we could.
Titan has been down for a while due to a Backbone link failure at #FTW-OMFS. It seems like the routerboard got water even though it is in a aluminium enclosure (Seems like some of them have water leakage). Ftw-omfs is trying to revive it, but let us see how it goes.
The backup backbone link which is pointing to lockjaw, is a dead end…So that will be moved to Saturn in the next two weeks.
Follow the #ctwug-bellville IRC channel for updates on Titan.
